Trying to use superlookup for the first time but error checking says “unknown statement: superlookup”
You will get that message if you have a line of code like this:
superlookup( ..... )
in which you have used the function as if it was a statement (hence, the ‘unknown statement’ message) but not if you have this:
field something formulafill superlookup( ..... )
Even so, there are problems with the function - see Superlookup( problem.
Superlookup( is a function, not a statement. It returns a value that you can use.
THAT problem with Superlookup( was fixed last fall.
Yes. THAT problem was fixed, but there is still a problem.
A formulafill that uses a superlookup( with a grabdata( function back into the original database now works correctly. Note that this fix only applies to formulafill – other scanning operations like select, find, etc. still do not work with this combination, and will be a bit tricky to fix.
