Selecting data from a Field with Variable Field Name
What I want to do is simply, from an active cell, select all records that have the same content as the active cell. For example I am in a filed call “State”, the content of that Field is “NY”, I want to have a procedure that when I click on it or execute it it selects all the fields that have “NY” in the “State” Field.
Panorama 6. Mac Pro late 2013, Sierra OS.
I have two local variables. The variables work fine, but my select statement does not work. It is driving me crazy. It should be so simple.
;Find same content in field
Local LFieldName,LFieldContent
LFieldName=info(“fieldname”)
LFieldContent=GRABDATA("",info(“fieldname”))
Select LFieldName=LFieldContent
Thanks guys.
George
What you are doing there is selecting all records where the content of the field equals the name of the field. There is a simple way to do this, using the fact that «» stands for the current field.
Local LFieldContent
LFieldContent = «»
Select «» = LFieldContent
The left chevron « is option-\ and the right chevron » is shift-option-\ on an American keyboard.
In the data sheet, you don’t necessarily have to write your own procedure to do this. Just control-click or right click the cell, and choose “Select Same Value” from the menu that appears.
If by chance he is in a different field when the selection actually takes place from when the variables were filled he could use the execute statement to handle things.
execute {Select }+LFieldName+{="}+LFieldContent+{"}
This assumes you are selecting from a text field. If not, you would eliminate the quotes around the LFieldContent variable.
Thanks Partner.
Works like a charm. And fast.
Best Regards,
George
Thanks Gary.
Another way to skin the cat.
Regards,
George
