I’m having a syntax issue - I don’t seem to have the right structure for a formula I’m using in a field. The formula should subtract hours worked from hours due, but not allow negative numbers. So if someone worked 5 hours and only 3 were due, I don’t want -2, just 0 in the field.
Here’s how I had done it in another program:
IF({HRS REQ}-HRS>0, {HRS REQ}-HRS, “0”)
Here’s my Panorama X attempt from reading the docs, but I’m doing something wrong:
?(HoursWorked < HoursRequired), (HoursRequired - HoursWorked), 0)
Thank you in advance for helping me get this.
Best,
Biagio
You have an extra right parenthesis. Aha, Dave beat me too it.
One clarification, in this case this isn’t a statement, it’s a function. Unfortunately the difference between statements (used in program code) and functions (used in formulas) is often confusing. I wrote a post about this topic last month, hope it might be helpful to you.
