Tom Cooper and I have put together a procedure which overcomes an aesthetic problem with the import of Pan 6 push buttons to Pan X. When a Pan 6 form containing push buttons is imported into Pan X, push buttons which looked like this:
are rendered as:
After being processed by our procedure, they look like this:
… and they still work. You can easily modify the procedure to produce different shapes, line thicknesses and font.
The procedure also (thanks to Gary Yonaites) fixes the two problems with converted data cells that I had raised earlier.
The procedure can be downloaded at https://dl.dropboxusercontent.com/u/1942634/Button%20converter.pandb.zip
michael
