Setting this:
splitmenutrigger menuname,menuitem
as the code to be executed when I click on a custom menu item, I get an error message:
Cannot set parameter 1 value.
A bug or my fault?
Setting this:
A bug or my fault?
Have you defined the variables menuname and menuitem?
local menuname,menuitem
Not the question you asked, but since you are writing new code, I suggest not creating a .CustomMenu procedure and instead embedding the code directly into your menu definitions, for example something like this:
menuitem("Gargle","CODE",{call gargleNow})
The variables were defined. I wasn’t planning on using a .CustomMenu procedure. I don’t know what I’ve changed since posting this query but I no longer have the error message.
I’m using variables to contain the sometimes lengthy code snippets and the menuitem(
and arraymenuitems(
functions accept them happily. It makes for neater-looking and more readable code.
