I doubt that the external drive matters but you can always do a test by moving a copy. The error message indicates an inability to write (save) so at some level the Permissions are preventing it.
Peter,
I read your conversation with Jim concerning keeping Inview alive. Iâm a longtime user of Inview and still using it on High Sierra with Pan 6.0. Are you still using Hindsight? if so, are you running Parallels with an mac OS? parallels website it should run, and James says he runs it with Catalina. any help or advice would de appreciated.
Steve
Steve,
I still have an old machine with El CapitĂĄn on it. I had a lot of trouble moving the back up copy of InView and panorama from the machine that died. I finally got it sorted and Iâm using it that way, now.
Iâm going to have to upgrade this old machine. I shied away from parallels only because I remember people reporting nightmares when it first became available. Iâm going to look into that myself.
I donât know if this was an any help to you, but thatâs all I have.
Peter
Peter,
Thank you for responding. Iâm in a similar situation wondering if the deactivation will work. Thereâs a lot of videos on YouTube about using 32 bit on Catalina. My thinking is like yours, what if it doesnât work for some reason. Iâm considering buying a 2015 13â MacBook and loading El Capitan & Panorama 6 then dragging my Hindsight folder to see if that will work. Hard to get clear direction. I tested last fall a online accounting software called zipbooks. It was free and allowed invoicing, contacts, checkbook, and expenses. It was simple enough but itâs in the cloud. Iâd like to chat by phone if you have a moment. Could you share your number.
Thank you,
Steve
Hey Jim,
I hope youâve remained safe in the pandemic. What a world.
If possible, I need to move my old, single-license copies of Panorama 6 and Hindsight 5.5 over to a different OS X 10.14.6 Mojave machine so I can migrate my laptop from Mojave to Catalina, if not Big Sur. Is there any way to do this? Can a Time Machine Panorama and Hindsight folder recovery on the existing machine then just be across the network to the new machine?
Hi Jim,
Iâm hoping that i wonât need to bother you any more with InView questions⌠with any luck this will be my last one:
Iâve been exporting my data to comma delimited files, which has been going well. The only problem Iâm having is trying to export the Estimates file. There doesnât seem to be a way, at least not in the usual âReports>Exportâ method. Is there a way to export Estimates?
Thanks, and happy TG!
Brian Smale
Copying your HindSight files should be fine, but Time Machine doesnât handle a proper installation of Panorama. Youâll need to run a proper installation process for Panorama 6. Youâll find plenty of notes about that on this site for just about every OS.
Hmm, I donât have any of those files to refer to, but I did look in the manual. It doesnât appear that either the Estimates or Opens Jobs files had an export feature built in.
Ok thanks for getting back to me Jim.
Brian
Brian Smale
206-818-3367
Jim,
First of all I want to thank you for the best support of an application I have ever seen, even extending beyond the companyâs dissolution. I will always have a warm spot in my heart for you and Inview. I have been stuck on High Sierra for awhile and have cloned my startup drive and am about to move to Catalina. When I need Inview I plan to startup from the other drive and use Inview. Should I expect any problems? I have tested this and it seems to work fine. I am just cautious about moving forward with the OS upgrade.
Best,
Park Street
Austin, TX
Jim-I was a longtime InView user. Years ago you designed a database for me to track my print inventory. I was able to continue using it (with some wrinkles) when I was forced to upgrade to Panorama X. I am still having some issues, though, and was wondering if there was some way to connect with you, outside of this string.
Thanks-
Harvey Wang
Iâll send you my email address via a private message
For those trying to export data from HindSightâs Catalogue or Contacts:
To export data from HindSightâs Panorama 6 Catalogue, see Catalogue Export
If you have need to export data from a HindSightâs Panorama 6 Contacts database, see Contacts Export
James, or others using StockView Catalogue. I had a question about the best way to get all the data exported from this part of the software, in order to migrate it into DAM (Digital Asset Management) software where these values can be stored in the DAM and in the embedded metadata. What Iâd found was for version 3, but I think is still the same with newer versions.
With StockView Catalogue open:
*From Search menu at the top, use âSelect Allâ to get all the records (you can also âtagâ the records you want, and then use the âSelect Tagsâ as another option). *
In the Functions menu, select the âReport byâŚâ feature, and from that sub-menu choose âExport Selectedâ (the manual says that this âExports the selection youâve made to a disk file in text or ASCII format. Youâre given the opportunity to name the file and choose where itâs to be saved on your hard drive.â).
The sample CSV (Comma Separated Value) text files Iâve done, when imported into a spreadsheet have the first row showing the field name in StockView (with Cross Refs representing Keywords). If the catalog has 500 entries and there are 501 rows (one for the legends), then I think that means I should have all of the data.
Can you think of anything I might be missing?
Many thanks in advance. My apologies in advance in replying to this thread, but Iâm unfamilar with this forum and itâs not that clear on how to start a ânewâ thread/topic.
Yours,
David
No problem that youâve replied to this thread, itâs a good place for anything âHindSightâ.
It seems like youâve got it covered, but in case you missed it, your post was preceded by one from me on the very subject.
Jim:
Thanks. Not sure how Iâd missed those two links.
Good info. Iâve bookmarked them for reference.
Yours,
David
Your best bet is to resort to your most recent back up to replace the file.
James - I was a long time InView user, 2000-2019. I recently had to upgrade to Big Sur from Mojave. In doing so I made sure export out my financials from InView but I forgot to export my equipment list.
I do have a copy of my InView but no longer have Panorama.
Do you or anyone you know offer a service to open InView files and export the data? I would need the Equipment Database opened exported as text file and I would also would want a PDF report showing all of the equipment.
Much Thanks!
No need to remind me who you are, Jon. I remember quite well.
Iâll have someone who can probably help you get in touch.
Thanks Jim!
