Panorama X 0.1.028 Build 2172 Release Notes
Panorama X 0.1.028 Build 2172 is now available. You can download this new version from the web site, or you can simply launch your current version of Panorama X and let it automatically update. If Panorama X is already running, choose Check for Updates in the Panorama menu.
This is a bug fix release, no change to the version number since there are no new features. The previous build had a serious bug that could cause the wrong record to be modified when using the Choice Palette feature, so if you use the Choice Palette feature, you should install this release as soon as possible.
  • Clicking outside of a Choice Palette on a different row of the data sheet no longer changes the value in the clicked row – it now changes the value in the original row as you would expect.
  • No longer displays Choice Palette unless there is at least one non-blank choice defined. In other words, if Choices option contains white space but is not completely empty, it will not display an empty radio button but just use the regular text editor.
This also corrected a problem I was having using the .ModifyRecord procedure where clicking outside an open edit box would return the name of the new clicked on field rather than the field that was actually modified.
