Good afternoon,
I have designed the attached form, the columns of which are obviously unaligned. I have arrived here by simple trial and error in placing and replacing the location of fields so that the print version of the form is properly aligned.
Is there a more formal way to align columns and one that will produce a version of the form that reflects the same position of the fields as they appear on the printed version?
Thank you.
