Is there a special way to manually enter a carriage return text array in PanX? In Pan6, hitting the Return key does the trick. But in PanX, although hitting the Return key does start a new line, a line-feed has been entered instead. Can a carriage-return be entered manually?
In my test, option-return still generated a line-feed and not a carriage-return. My suggestion would be to add a line of code to the Code section of the Field Properties panel.
MyField=lftocr(MyField)
Now every time you finish editing that field it automatically converts the line-feeds to carriage-returns.
