Duplicate entry
Greetings. One of the things that still has not been implemented is to not allow a duplicate entry. It seems after two years of Pan X this would have been implemented. There have been many additions and procedures that have been added, but to not have a “basic” that used to work in Pan 6 is not good.
There is a way to simulate the action of no duplicates as was found in Panorama 6. It will involve a new procedure and a call in the procedure code of each field you want to have the no duplicate option. First you need to make a new procedure which I am calling .NoDuplicates. Here is the code for that procedure:
return
modify:
if arraycontains(listchoices(info("fieldname"),¶,2),«»,¶) and «» ≠ ""
    alertcancelok "Warning: You are attempting to enter a
duplicate value. Click Ok to add anyway, or
Cancel to re-edit cell."
    if info("dialogtrigger") = "Cancel"
        editcell
Next, you have to add a call in the Code pane for all the fields you want to not allow duplicates.
That is all there is to this scheme. I don’t know how fast it might be compared to a built-in version that Jim will implement one day but it does the job for now. The warning dialog has the same message as the Pan 6 warning except the icon is slightly different.
Thank you. I will give it a try.
Just a note to point out that the procedure code was originally missing the leading return statement that got lopped off when I first pasted it in. I have since edited the code and it should now be correct as shown above.
Worked like a charm. Thanks again Gary
#6
It works, too, without the return statement. What is the sense of it?
#7
It is what the Help file indicated should be used. Other than that, I really don’t know.
#8
Here it does not work, if I add the return statement.
#9
Do you by any chance also have a return in the field Code pane as well? If I put one there in addition to the one in the called procedure it will work for me either.
#10
In the example in the Help file, there was other code above with a click: label. The Return is there to keep that code from continuing on through the modify: code.
#11
Panorama X 10.2 introduced some significant improvements to automatic field code, now allowing you to run different code when different actions occur, for example code run when the field is clicked, vs. code run when the field is actually modified. To do this, you must add specific labels to the code, for example click: or modify:. If those labels are present, the code doesn’t run from the top of the procedure, as it normally does, instead, it starts running from the label.
In previous versions of Panorama, the automatic field code would only run when editing was finished and the field had just been modified, and the code would always run from the top. If you leave out the labels, it will still work that way. In this particular example, modification is the only action that you have written code for, so you could leave out the initial return statement and the modify: label, and just start with the first line of code (in this case if arraycontains…).
This special behavior (starting at the label instead of at the top of the code) only happens in special circustances, specifically, only if the code is in the Code panel of a field – OR if the Code panel calls this procedure and does nothing else. If there was any other code in the Code panel besides the call statement, it would not jump to click: or modify:, but start at the top of the .NoDuplicates procedure (if there is more than one line of code in the Code panel then the special labels must be put in the Code panel itself, not in a subroutine).
So, if the .NoDuplicates procedure is called from somewhere other than the Code panel, the code will start running from the top. In your example that is probably never happening, so that initial return statement isn’t coming into play. But if that ever happened by accident, you might want to handle that situation. By putting a return statement at the top, you make sure that the code doesn’t fall thru and run your modify: code. Or, if you did want that code to run, you could leave out the return statement. Or you could put some different code at the top of the procedure and a return statement, to perform some different action in that case.
Personally I think it is usually a good idea to put a return statement on the top in this situation, just in case this procedure gets called in some way I wasn’t expected. That insures that nothing happens in that case. Or, since modify: is the only action being handled by this particular action, you could just leave out the return and the modify: label and let it work the way it did in previous versions of Panorama.
I don’t suppose you are running Panorama X 10.1 or earlier? It would have to be either that, or you left off the modify: label.
