Using a database migrated from 2.1.2 to 6, I can’t complete entries before the field closes. In DATE fields “illegal entry” keeps popping up.
If the Return or Date key is pressed, the Input Box will close. It will also close if you click outside of the Input Box. If you are using a laptop you may be inadvertently clicking by brushing against the track pad.
Nope. On a MacMini. I even switched keyboards out.
Well, somehow you are getting extra clicks or key presses. Panorama 6 has been in use for 8 years, if there was a problem in this area I’m sure you wouldn’t be the first to discover it.
Agreed.
I’m trying to Colombo it down. Appreciate your help.
