Data dictionary problem
I’m trying to get a datadictionary setup in PanX without much luck.
I want to have the dictionary in a Field called FieldA. After creatiing a new database, I immediately change the field type to binary and then change the field name to “FieldA”. in the Funciton section I entered:
initializedictionary(“Address”,“3987 Olive”,“City”,“Tustin”,“State”,“CA”,“Zip”,“92841”)
After that I use the Field-Morph-Recalculate Field.
I can see binary data in the data sheet so I assume that it is setup properly.
If I make a procedure that has one line in it of:
message (getdictionaryvalue(“FieldA”,“Address”))
When I run it it says that: "getdictionaryvalue( dictionary parameter must be a valid dictionary
What have I done wrong with this?
You need one more parameter in the getdicitionaryvalue( function.
The field name should not be quoted. The correct code is:
message getdictionaryvalue(FieldA,"Address")
The way you wrote the formula, you were giving it the actual text FieldA as the dictionary value (in other words, the letters F i e l d A), when what you wanted was for the contents of the field to be passed.
