Can't assign values in records displayed by outlinelevel statement
From d/b alpha, I open d/b beta which has 690 records. The procedure in alpha runs this code to summarise the records in beta and assign a value to the Kounter field in each summary record:
field Kounter fill ""
field SourcePIC groupup
field TransferDate groupup by day
field RFID count
field SourcePIC propagate
field VendorName propagate
field RFID unpropagate
select RFID > ""
removeunselected
outlinelevel 1
field Kounter
    let I = 1
    loop
        Kounter = I
        I = I + 1
        downrecord
    until info("stopped")
When it comes to assigning values in the Kounter field, the display reverts to all records without any summaries and assigns 690 values.
If I put the identical code in a procedure in the beta d/b, it does what I want, which is to assign values only to the summary records. I’m using a loop to assign the values because I tried using
field Kounter sequence 1,1
but that just put the value 1 into every summary record.
Why is this happening and how do I get around it?
The sequence command is supposed to restart the count for each group, so that’s the correct behavior. Rather than a loop, you could use
field Kounter
formulafill seq()
I can’t duplicate the problem you are having with the loop. I just tested the ending of your procedure . I added a Kounter field to a database that had been grouped, and ran this from another database.
OpenFile "Test Fields"
OutlineLevel 1
field Kounter
    let I = 1
    loop
        Kounter = I
        I = I + 1
        downrecord
It only put numbers in the summary records.
Yes - I missed that in the documentation.
The seq( function works.
The original problem lay in the removeunselected statement - that returned the data sheet to a full listing.
Thanks Dave.
