Array Evaluation and field value assignment
If a field named ‘rawCgiExtra’ has this value…
RR~2017-01-17 23:08:59~pos~0~pic~1~pump~0~sfc~1
will the following formula in a procedure put the text ‘0’ in a text field named ‘pos’? If not, why not?
pos = Array(rawCgiExtra,val(ArraySearch(rawCgiExtra,“pos”,1,"~")+1),"~")
It does - for rawCgiExtra and pos being either fields or variables. Why would you expect otherwise?
For yet to be understood reasons,
posText = array(cgiExtraParameters,3,"~")
works but
posText = Array(rawCgiExtra,val(ArraySearch(rawCgiExtra,“pos”,1,"~")),"~")
does not. I’ve been staring at this for too long and thought if I asked others, I’d be put out of my misery of overlooking something obvious. The 1st format works but I can not count on the order of each set of values so I was going to use the search method, but alas, it is not working.
I’m not thinking that it matters, but this is in a shared Enterprise database and these statements are in the procedure that is run when the record is added via the use of a url.
… and specific to the original post
pos = array(cgiExtraParameters,4,"~")
works, while
does not. The posText and the pos fields are both empty using the 2nd method.
I was going to suggest that you might have a variable called rawCgiExtra but I tried that and it still works. I have no experience of using Enterprise, so maybe the problem is there. Have you tried it in a non-enterprise d/b? Have you tried it with variables rather than fields? Have you tried it with different field/variable names?
I note that pos has become posText but that doesn’t change anything. I tried Pan X as well and it works there.
I don’t know why your formula isn’t working, I assume there is some critical missing piece of information you haven’t told us about because you don’t know it.
However, I have a suggestion. It seems to me that this formula would come up with the value you are looking for.
tagdata(rawCgiExtra+"~","~pos~","~",1)
I tested this, and it works for me. It seems like it is a simpler solution, also. If it doesn’t work, maybe the data in rawCgiExtra isn’t what you think it is.
#6
Thanks.
I was confusing the automatically created variable ‘cgiExtraParameters’ with my field name ‘rawCgiExtra’ and I had not yet shoved the variable value into the field name at that point in the procedure (thus they could not be used interchangeably.) I hadn’t noticed that I was inconsistent in my use of the two items.
Plus, Jim’s suggestion to use TagData also was simpler and it fixed a new problem of searching for a ‘tag’ which did NOT exist in the cgiExtraParameters, so when I added 1 to the search result of 0 to get that missing tags’ parameter, I then erroneously got the first element in the text array. Using TagData properly retrieved nothing.
Robert Ameeti
