Address label problems
I have an address label form that was created in Pan 6 that uses up to eight conditionals on the label. The number of lines of the label would move with the conditions. In Panorama X, if a conditon is not met, a blank line is left instead of the lines below adjusting. For example, Company, Contact, Address, City, State Zip. If a condition is set so that if there is a company name display the company name, if not don’t display anything.
In Panorama 6, if there was a company name, it was displayed on the first line of the label. If not, The contact would be the first line of the label. In Panorama X, The label begins with a blank line when there is no company name. It also creates blank lines in the middle of the label based on conditionals. Needless to say, this makes swiss cheese of the labels.
Is Panorama X not capable of adjusting the spacing of lines on labels based on conditionals?
Enclose your formula with the linestrip( function.
Is the Collapse Blank Lines option checked?
Thanks Jim. I didn’t even see that.
Thanks Gary.
