The Construct->Fields and Variables menu item constructs a set of field names and Text Editor Objects. Is it possible to tweak it so that a set of Text Display Objects can be created?
I have also wanted this feature from time to time, so perhaps this will get added at some point. In the meantime, the source code is editable so you can reprogram it any way you want. This would probably take more than 5 minutes and less than an hour.
Thanks Jim - it’s probably quicker to create them by hand this time.
