Hi,
I have become addictive to running Pan10.2 using Terminal, this is a marvelous help for debugging!
Away from home, I have installed Pan10.2.0.b15 (3656) on a MacBookAir running MacOS 10.15.7. (I have problems with b18 but this is another story!).
All OK with b15, however when I try to install the debugging tool to use Terminal (from Install when in PanX Preferences) I get the error message:
FileSave error: The file “Run Panorama X Using Terminal” doesn’t exist.
Clearly I can still file the log in BBEdit, but this is less convenient.
What should I try?
Cheers,
A.
