This is an aspect of Panorama X 10.1 (I hesitate to label it either a bug or a feature) which I discovered a year ago, filed away in my mind but then forgot, because I have just spent a long time trying to debug a procedure in 10.2.0.b12 (3581) and eventually remembered I had encountered the same problem before!
Thanks to local variables etc., recursive procedures and subroutines work fine in Panorama X. Previously Michael Kellock has queried how many levels of recursion might be possible, but I’ve had no problems in that regard.
However, if a procedure/subroutine calls itself recursively from within a looparray
loop, that stops looping.
The example below assumes a database of heirarchical tree data containing (at least) 3 fields:
KEY
— a unique key for each record created usinguniqueid()
—H1
,H2
,H3
, etc.Name
— text to be displayed for each recordChildren
— a comma-separated array ofKEY
s of other records which are children of each record
Thus, if the record for which KEY
=H1
is the root of the tree:
H1
’sChildren
might beH2,H3,H4,H5,H6,H7
H3
’sChildren
might beH8,H9,H12
H8
’sChildren
might beH13,H14
H13
’sChildren
might beH24,H25
H24
’sChildren
might beH30
H30
is the end of that particular branch if it has noChildren
Any record may have ≥0 children; none may have >1 parent (and there are no feedback loops or incestuous pairings: these are strictly heirarchical data, such as directories and files).
This procedure and its recursively-called subroutine, List
, ought to enumerate all the children of H1
as lines in the log file, with the KEY
s in the left-hand column followed by the Name
, and with the Name
of each generation (level of the tree) indented by one more tab than its parent:
shortcall List,"H1",tab() // Recursively list all descendents of H1
stop
List:
local ThisKey,Indent,Element,Title
ThisKey=parameter(1)
Indent=parameter(2)
Title=lookup("",KEY,ThisKey,Name,"")
if Title≠"" zlog ThisKey+Indent+Title endif
looparray lookupmoredata(Children,""),",",Element
shortcall List,Element,Indent+tab()
endloop
return
However, the result is only the first child of H1
, the first child of that child and so on, one entry per level (generation) until the end of that particular branch. The remaining children and their children (etc.) are not listed because, following the first recursive call to List
each time, the loop terminates, thus it can have no more than one iteration.
By changing looparray
to loopwhile
and working through the array manually, it correctly enumerates the whole tree:
stop
List:
local ThisKey,Indent,Element,Title,Offspring
Indent=parameter(2)
Offspring=lookupmoredata(Children,"")
loopwhile Offspring≠""
Element=arrayfirst(Offspring,",")
Offspring=arraylefttrim(Offspring,1,",")
endloop
return
(Perhaps that’s not the most efficient way to loop through array elements without using looparray
. However, it works for demonstration purposes and, importantly in this case, like looparray
it will execute zero iterations if the array is empty.)
There’s nothing in the documentation for looparray
to say it’s not compatible with recursion. It notes that it ‘uses special optimizations to reduce the amount of processing that needs to be done on the array each time through the loop’ and that is expanded upon by David Thompson in this post:
However, neither that nor anything else I’ve read suggests it might interfere with the procedure stack and therefore cause recursion to break, but I suppose it might never have been intended to coexist with recursion either, as other loops clearly do. In that case it’s not a bug as such, but neither is it the most desirable of features.
I considered submitting a correction to the documentation for looparray
to add a warning that it should not be used within a procedure/subroutine call which calls itself recursively from within looparray
. . . endloop
— if only to remind me in future! — but I thought the behaviour ought to be noted first.
