This didn’t matter in Pan 6…in Pan X, the procedure fails when trying to autofill a field which is not visible in the datasheet, but works only if the field in question is visible when the procedure is called.
It isn’t shown in your screen shot, but I assume that the code contains this line:
field ReceiptDue
This code will not run if the field is not visible. You cannot switch to a field that is hidden. If Panorama 6 allowed that, it was a bug.
