Open the Preferences dialog, switch to the Server pane
If Panorama X Server is running, stop it
Start Panorama X Server. It will automatically update before launching.
The changes in this release are:
Panorama Video Training now allows ProVUE to update the list of videos at any time (before the list could only be changed by releasing a new version of Panorama). This will be used to post session recordings during the upcoming courses.
New Live Course Calendar window facilitates scheduling of Zoom sessions (Help menu).
Through an oversight, the OPENWEBMAP statement was not brought over from Panorama 6, now it has been.
Hack to make sure that in the Database Options>Relation panel, the key option checkboxes are always visible, even if the dialog opens to this panel. To make this work, had to remove the bezel background from the key options box and just leave no background (hence white). When switching from another panel, the background is correctly set to the nice looking bezel. Hopefully someday the underlying problem can be resolved and this hack removed.
The GetCityStateZip statement no longer gets confused if the address ends with US (or any variation of the spelling of the US) or Canada.
Tweaked server usage code to make it more accurate. Should no longer count downloading static files as web usage. Ping and Snapshot quries are no longer counted as usage. Inbound data is now counted more accurately (counts the actual text, instead of the raw dictionary)
New functions for working with time zones – converttimezone(, daylightsavingstimeoffset(, nextdaylightsavingstimetransition(, info(“localtimezone”), info(“timezones”), info(“timezoneabbreviations”), timezoneabbreviation( and timezonename(. Also, “local” is now allowed to specify the local time zone (in addition to “”).
Now must be logged in to an account to run any beta version of Panorama X.
I’ve uploaded a new version, build 3575 (the previous build was 3574). I’ve updated the link above, it now points to the latest version. Here it is here also:
I’m quite confident that the problems with the Live Course Calendar are fixed – the problem was a stale cache. There’s a programmer saying that goes – There are only two hard things in Computer Science: cache invalidation and naming things. Well, I just proved the cache invalidation part. Turns out the cachepolicy option of the url( function can be really important! Didn’t have that option in Panorama 6.
I’m seeing an error “Your user account is not authorized to run Panorama X 10.2.0.b12.” after Panorama has been running for awhile, and after the you are approved message. Sometimes just as I have started to work, but more frequently when I come back to work on my machine after awhile. If I quit and reopen, everything works correctly
Do you have more than on Panorama account? The beta will only work with the account you signed up for the course with.
However, I thought it only checked for this once when Panorama launches. I’m surprised that this would come up any time other than the first 10 seconds Panorama was running.
I think this happens when I’m connected to the internet with a VPN and the computer goes to sleep. When it wakes up the VPN reconnects. This may be more of an issue with a WiFi connection, but I am not sure yet. I will keep testing today.
