Hi everyone!
I’m trying to finally move some files to Pan X, (and the video tutorials have been fantastic, btw!).
An issue I’m having is that we have files where we would make a dictionary in a record.
For example:
When was the last time someone got Sent one of our 3 mailers. It would assign that record a corresponding value/key and plug it into the field that held it like this:
˛Mailer 1ˇ10/15/2022˛/Mailer 1ˇ
We ONLY need to know the last mailing, so the auto replacing of a value per key only once was perfect.
Then in the form. I had a script that used getdictionaryvalue()
to display what was in that field for each mailer so that the folks on the phone always have it for that user.
So far, what I’ve read is that PanX dicts are in the same format as Objective-C ones, and Pan6 ones were in a very different format, and that there’s some auto formatting PanX can do on them to change them to the correct format. (Which is great, dictionaries/hashmaps are my favorite data structure)
However, trying to give panorama the old dictionary from the field either with set/changedict or with getdict or putting in in a variable and then running those functions on it throws back
Unknown statement: getdictionaryvalue
What do I do to give that statement the correct data from a dictionary stored in a field?
Is there an easy fix for changing all these dictionaries to proper ones?
