Know this is Pan X 101, but can’t find the answer.
I have built a form with ten different fields and when I finish putting in information and want to go to the next field, is there a key stork that can get me there. I tried like the tab key and return it doesn’t work, how can I go quickly from one field to the next???
In the Text Editor Options pane, check the Tab checkbox, for each of your text editor objects.
Choose the appropriate tab order in the Form Properties pane.
FYI, you should be able to do what Dave said all at once – select all of the Text Editor objects, then check the “tab” option.
Guys, perfect and many thanks
