You all were so helpful regarding an earlier question, I thought I’d throw out another one on a different topic.
I’m generating a bibliography from my Biblio database, which consists of various items that are tagged in field B according to their class, e.g. book or blogpost. I’m going to pull the relevant records into another database using arraybuild, and I can write the various formulas to extract the text strings needed, but how can I get it to format the items according to the tags in B (if/then situation)?
For example, for items tagged “blogpost” I need to use the formula:
richtextdisplay(D+cr()+C+" "+"<i>"+E+"</i>"+". "+F+".")
While for a “book” it is a little different:
richtextdisplay(D+cr()+C+" "+"<i>"+E+"</i>"+". "+AB+": "+AA+".")
There are 10 different formulas total. Thanks in advance for your help!
