The Help wizard appears to have been off line for the last couple of days - is it or am I just not finding it?
I am not sure what you are meaning with “Help wizard”. If it is the “Panorama X Help” in the Help menu, I have not noticed any issues with it, and I have used it intensively in the last days.
I’m also puzzled as to what you are referring to – the Help wizard works fine for me and is in the Help menu where it has always been found. If it is not there I would suggest re-installing Panorama.
The Help window opened but it was empty - re-installing Panorama X solved the problem.
That happens to me from time to time.
