I suspect the problem is that when the variable name is used alone, it is calculated immediately – before the variable has actually been defined. Panorama has a special case for when a function parameter consists of nothing but a single operand – for speed it just uses the value rather than actually processing the formula. Normally that is fine, but it doesn’t allow for the fact that the cache( function can modify subsequent parameter values.
Is this a bug? Maybe. On the other hand, I don’t think there is any place in the Panorama documentation that states that function parameters are evaluated from left to right. Your code is assuming that is the case.
Here’s another way to write the formula that does work. This version makes sure that cValue is fully defined before the ?( function is evaluated. I think this is a better approach than relying on the quirk that the order of parameter evaluation is different depending on whether the parameter is a single operand or a more complex formula.
ignore("",cache(“DataValue”,“cVALUE”))+?(cValue=“TestValue”,“FAIL”,cVALUE)
Note that this issue is completely different than the other cases where +"" is used, at least as far as Panorama’s internal code goes.
Basicallly, I would recommend avoiding use of the cache( function within any function with multiple parameters, not just the ?( function.
