Frequently a boolean function starts with a relatively complex evaluation. Then if the result meets some expectation, the whole evaluation is run again.
For instance,
?(arrayfilter(relatedarray(…)) ≠ “”,arrayfilter(relatedarray(…)),"")
In a procedure I can simply run it once and load the result into a variable, then use the variable in my function. But when used in a situation requiring the whole thing to be a single formula it seems there must be some way to apply it without repeating:
?(arrayfilter(relatedarray(…)) ≠ “”,(UseIt),"")
Maybe something like this exists and I’ve overlooked it. Or perhaps there’s another way.
