I was able to come up with a heavy-handed work around to get this type of report printout with alternating record backgrounds. It requires adding a background Image Display Object and formula to the Data tile and enhancing your print or preview procedure (or creating a new one if you don’t already have one).
On your Report Form in Graphics mode:
Select all the current objects in the Data tile & “Bring to Front” (Objects/Arrange menu).
Create a new Image Display Object the same size as the text area of the Data Tile.
Enter this formula in the Formula panel of the Image Display Object:
catcherror(“%%FFFFFF”,?(Temp=1,“%%EEEEEE”,“%%FFFFFF”))
The catcherror function will keep an error from being generated if the Temp field is not currently added to the Data Sheet. The two color values I have used are white (%%FFFFFF) and light gray (%%EEEEEE). You can adjust these to suit your preferences.
In your Print or Preview Procedure:
Add this code before your Print or Preview statement:
addfield "Temp"
Field "Temp"
fieldtype "INTEGER"
formulafill seq() mod 2
//Print or Preview here
After printing is all done, run this code to remove the Temp field:
Field "Temp"
deletefield
This code creates a temporary integer field and populates it with alternate 1’s and 0’s using the seq( function and the mod operator. Now when the report is printed any line with a 1 in the Temp field will have a white background and any with a 0 will be gray.
Yup, Gary’s solution is the only way this can be done in Panorama.
However, if you are printing only data records, I think you can skip the part about adding a temporary field, and instead use the info(“printsequence”) function.
The formula in your Text Display object would be something like this:
"%%"+?(info("printsequence") mod 2,"EEEEEE","FFFFFF")
