I am using the Summarize & Analyze favorite below.
In Expense Type, I have two categories: Fixed Expenses and Variable Expenses.
My report shows the Fixed Expenses first whereas I would like to list the Variable Expenses first, regardless of whether their amount is larger or smaller than the Fixed ones.
I did a test and verified that Group Up will sort Choices in the order choices are listed.
There are 14 lines in your Summarize & Analyze specification. I looked at them closely, and it is doing exactly what you have told it to. Line # 8 tells it to sort the Expense Type in descending order by the amount. So the Expense Type with the highest total will be listed first, followed by the next highest, etc.
Since that is not what you want, remove Line #8. At that point Line #7 does nothing, so remove that as well.
