Is there a work-arounbd for installing Pan6 to macOS Big Sur 11.1? Client reports download is possible, but unable to install…
Thanks for any advice.
Starting with macOS 10.15 Catalina, macOS only supports 64 bit applications. Since Panorama 6 is a 32 bit application, it cannot be installed on anything after macOS 10.14 Mojave.
Thanks, Jim, for your prompt, but disappointing reply. Nothing lasts forever, and Pan 6 has been a good friend for a long time. Old friends are hard to come by.
Worth knowing, using Parallels with El Capitan installed, I’ve got Pan6 running very reliably on Big Sur
I just installed Parallels for a client using Mojave on Catalina. Works great.
