UNIX Date Conversion
Is there anything I’m overlooking in Pan X that would help me convert a UNIX date to a typical date and time format?
So far I’ve had little success in adding the UNIX date (seconds) to 1/1/1970 then converting it to a date pattern. My results have been all over the place.
A Unix date?
Seconds since when?
Since you want both date and time, I would suggest adding it to the superdate for 1/1/1970, and that should give you the superdate you are after.
datepattern(regulardate(UNIXdate+superdate(date("1/1/1970"),0),"MM/DD/YYYY")
timepattern(regulartime(UNIXdate+superdate(date("1/1/1970"),0),"HH:MM:SS")
If all you wanted was the date, you could divide the UNIX date by 86400 seconds per day, and add that to 1/1/1970.
datepattern(UNIXdate\86400+date("1/1/1970"),"MM/DD/YYYY")
I had to subtract 25180 from the unixDate to come out with the correct value.
let unixDate=val(shellscript("date +%s"))
let unixConstant= superdate(date("January 1,1970"),time("12:00 AM"))-25180
message superdatestr(unixConstant+unixDate)
25180 is the correction for your time zone. Your unixDate is Greenwich Mean Time.
Thanks guys. I was beating around the right bush but not quite getting there. - especially in trying to convert 1/1/1970 to the correct seconds. Now I can retrieve a time stamp and even convert it to the desired time zone.
:slight_smile:
I came across the need to convert to Panorama supertime to Unix time:
Convert Panorama supertime to Unix time: add 2082844800, which is the number of seconds between 1/1/1970 and 1/1/1904. They only differ by the year that they count from.
You also have to convert your local time to UTC. Panorama has a function for that, and functions for extracting dates.
That was true in Pan 6 but it remains unimplemented in Pan X.
You can use the converttimezone( function to adjust for time zones.
unixDateConstant=converttimezone(superdate(date("January 1,1970"),time("12:00 AM")),"UTC","")
This will adjust the unixDateConstant for the local time zone.
