If you look at this image, could someone explain why the SS Couns field is formatting the entry in this pattern? xxx-xx-xxxxxxx
I’ve even copied another text object which doesn’t format itself that way and pasted it into this slot, but it still formats itself this way. For example, I option-copied the SK Couns field with the same word in it and put it in this SS slot, renaming it SS Couns and it still reads Mag-en-talling.
Thanks!
Thanks!
