Looks like this feature is way more popular than Jim ever imagined!
Iām going to go with the thought that we are better trained today to not whine about the things that may not yet be there. That Pano X is a work in progress and that it is not quite ready to be judged.
Robert is dead right. A lack of loud complaint doesnāt signify a lack of desire.
I hope this cuts the line and gets to the front of the list. I miss it terribly.
I found it. I mistakenly looked in the text control in the object pane.
Or not. How do i make a button anything but white?
Make an object of any size, shape, or color you like including a graphic or a Font Amazing icon and put whatever code you want in its procedure box. Voila, a custom button. The actual buttons are limited to what Apple provides.
You can go to the Help menu and choose Panorama Database Exchange. When that window opens you can find my Custom Button Generator file on the scrolling side panel and download it. This will allow you create an endless variety of fully customizable buttons.
So still no Tab direction feature after over a year of bringing it up. Iām looking for a program that supports it, any ideas?
No idea. I would only say that some features get added pretty slowly in Panorama. Jim obviously has a huge list of features and tweaks to implement and he has to prioritize. This one is clearly on a low priority list.
Iād love to see it return too, but with the passage of time, it has become somewhat less critical to me and certainly not enough of a reason to abandon Panorama.
Peter
This will definitely get done eventually, as I mentioned before, Iām a fan myself (thatās how I thought up the feature in the first place). But itās not technically trivial, and very few users know about it or used it. By my count just over 1% of forum members have asked about it in this thread. Iām sure there are others that havenāt said anything, but still thatās maybe 2-3% of forum members, and probably a smaller percentage of overall Panorama users (I assume forum members use more Panorama features than non-members).
As for other programs that support it, as far as I know Panoramaās implementation of this feature is unique, though I could be wrong.
If you look at the release notes for the past year there have been hundreds of changes made. Obviously, every item canāt be on the top of the priority list.
Me too! I donāt use Panorama that often, but made the jump to X. Not happy that I have to do a workaround just to fill in a column of data in the data sheet! Please include it ASAP - thanks,
Eric Rivedal (User since Overviewā¦ ā 84?)
I thought Iād posted this suggestion long ago but apparently not. What Iāve done is put this in the .Initialize
procedure of my more frequently opened databases:
definehotkeys "global", "control-tab", "downrecord editcell"
ā¦ and a simple Control-tab gives me a vertical tab - left thumb and index finger trigger it easily.
Setup a Keyboard Maestro macro for Enter - Down Arrow and give it whatever keystroke you want. You can set it in KM to just be for Panorama X and activate/inactivate it there at will. Not (much) harder to set up than the Pan6 way and nearly as easy to use once setup. There are probably other macro programs that could do the same, perhaps cheaper; KM was just the one I chose after the virtual death of Quickeys. Like Panorama, KM appears to be able to do very complicated things and may take awhile to learn such, BUT simple things, like the above, can be figured out and done easily and quickly.
Thatās a good idea. I havenāt used Quickeys in a long time - couldnāt find any news that it was no longer supported, but they still have a web site at Startly for some reason. Iāll look into Keyboard Maestro, but I also liked the global routine that allows you to program it right into the database. For now i just made a form that has ādownrecordā for the procedure on the last editable field and thatās working. Thanks to all,
yepā¦ Iām another one who used the TAB DOWN feature quite often in Pan 6. And today, Iāve come looking for it in X. Itās very helpful when youāve got several duplicate records, but just need to tab down the list to change, say, the date for each.
I suspect that this can be done using Karabiner Elements, which everyone who uses Panorama on a laptop Mac probably uses anyway.
I doubt that most Panorama users have ever heard of this program, but it is definitely one of the first things I install on a new computer. I always use it to make the right option key function as an Enter key. Karabiner Elements is free and available here:
Well now youāve heard of a second person! I use it all the time. I was wondering myself where the oprion was in X but figured I wasnāt just yet finding it. Honestly I find X so much less intuitive than beofre, itās a huge learning curve IMO.
I remain hopeful that Tab Down will be coming in the next update. Trying to move vertically through a couple hundred records for some quick data entry frequently had me entering into the wrong field.
