If superalert
's options parameters are set to {height=130 width=150}
, for example, the alert window opens at the set height but the full width of the screen. If the positions of the height and width settings are reversed inside the brackets, the window opens at full screen height but to the width set.
Adding a space after the final number and the close bracket {height=130 width=150 }
, works as expected.
This means that some examples in the superalert help page, for example
superalert message,{height=-36 width=500}
, will not work as expected.
