Step Not Working
When trying to step through Procedure code in Pan X, the breakpoint moves to the end of the procedure instead of halting at each code line. If there is a ‘call’ statement, then the program flow will enter the subroutine. Otherwise, flow proceeds all the way to the end without stopping at each code line, as anticipated.
Is there a trick I am missing to using Step to debug a Procedure?
Here is an example code, which proceeds all the way to the last line after clicking Step once
select «Exluded» = "No" and «Categories» contains "Blah"
field AKA
groupup
field Charges
total
field Quantity
count
field «Unit_Cost»
average
outlinelevel 2
field Charges
sortdown
An old story; check in Bitbucket. I hoped it would be fixed by now, but evidently it’s not. You can put breakpoints in your procedures to substitute for the missing functionality.
