Can shared databases (shared via Enterprise) be opened with “OpenSecret()”?
My database crashes big-time if I try to do that, and I just want to determine if it’s my coding skills (probably) or a limitation with shared databases?
Thanks,
– Mark
Thanks,
– Mark
Yes, they can but they still try to connect which can cause a long delay if they can’t find the server.
Follow-on question: if an Enterprise/shared database is opened with OpenSecret
why would the menu change from my “custom” menu to a standard menu?
Sequence:
.Initialize
FileMenuBar "Action -Wizard", ""
in the .Initialize
procedure. It’s supposed to look like this:.Initialize
completes, the menu has different items in it, like this:FileMenuBar "Action -Wizard", ""
is called before opening the shared database, the file menu looks like this (Note: no “Action” menu):Here’s the code that opens the shared database:
Local aDB
aDB = FolderPath(DBFolder())+"mySharedDB"
OpenSecret aDB
If I switch out of Panorama, to any other app (Finder, Chrome, etc), and then return to Panorama, the menu has returned to its “correct” state (See step #3, above)
I did try adding the following after at the end of .Initialize
, just in case it was an “event loop” issue, but to no avail:
Global ExecuteASAP
ExecuteASAP = {
Undefine ExecuteASAP
FileMenuBar "Action -Wizard", "" }
Any ideas on how to address this?
Thanks,
– Mark
I can’t speak to your secret database issue, but problems with menus not updating properly, especially when opening database, were an ongoing problem with “classic” versions of Panorama. I put a lot of effort into trying to fix this, and made some progress, but never could get it to work 100% correctly.
