I’ve got a numeric field. Some cells are empty. Some cells have a value of 0 in them. Other cells have various other numeric values in them. Is there a way to select only the blank (empty) numeric cells without also selecting those with a value of 0?
Select(MyField = 0) selects blank cells as well as cells with 0 in them
Select(Str(MyField) = “0”) selects blank cells as well as cells with 0 in them
Select(Str(MyField) = “”) doesn’t select anything
There is a complicated way to do what I’m after: what I do is FIRST convert the entire field to a string field. Then select blank/empty cells. Then concert back to numeric. It seems when converting a numeric field to a string field, Panorama doesn’t put “0” strings into the cells if blank.
Perhaps there is a method of detecting empty cells vs. cells with a value of 0 in them while the field is still numeric? Any ideas?
FYI… I’m still using Pan 6 for this project, so if this changed in Pan X, suppose that might be different. Thanks!
