Select records based on a formula
I can not figure out why this simple select formula is not working.
vInvoicePeriod variable has the value of “Aug-2017”
datepattern(DatePaidInFull,“Mon-YYYY”) = vInvoicePeriod
You’re not giving us much to go on. What does “not working” mean? Error message? No data selected?
Where did you type this formula – into the Find/Select dialog?
If this is a procedure then where is the select statement?
In general this seems like a formula that should work, so there must be some other detail you are not mentioning that is the problem.
Im sorry Jim,
I think Im tired, I just noticed it did not work because there was no data to match. It does work, Im the one that is generating errors. :slight_smile:
