If a file contains an Initialize procedure, it prevents the script below from successfully running.
RememberWindow
OpenFile “OtherDB”
OriginalWindow
If the OtherDB does not contain an Initialize procedure it runs fine. If the OtherDB does contain an Initialize procedure, it stops on the newly opened db without returning to the original db even if the Initialize procedure has nothing or just a nop. If the OtherDB is already open, the procedure returns to the original window as desired.
