How do I print a form in Landscape in Panorama X?
The usual way, use the Page Setup dialog to select Landscape orientation.
The difference from Panorama 6 is that Page Setup sets the orientation for every form in a file. You can programmatically set the orientation when printing if you print using printtopdf.
