Popup Menu problem in View-As-List
Popup menus set to be Transparent don’t work in the Header of a View-As-List form. When visible they work fine. Transparent or visible, they work in other forms, so it’s apparently this specific combination.
popup
Another issue seemingly unique to View-As-List is in objectino(. For instance, objectinfo(“name”,info(“clickedobjectid”)) returns nothing in a View-As-List but does work on the same object in a standard form.
Duly noted.
