Pop Up Menu Item problem
Hello Friends,
I have created a Pop Up Menu Item with about 20 items separated by commas. One of the items has 3 commas in its name. Is there a way to not have the menu treat them as separate items? I have tried putting the name of the line item in quotes but that did not work. In Pan 6 you could select a semi-colon as the separator. Any ideas would be appreciated.
In the Popup Button Options panel change the Mode to Formula. In the Formula panel put brackets or quotes around your existing formula and replace your existing comma separators with returns (leaving the commas in any item name that contains them). In Panorama 6 the mode was always formula and the formula default was a replace( function that changed whatever your current separator was to a return character.
Check out the full information in the Help file:
