I am getting some strange variable names returned when using dbinfo("permanent","mydatabase"). Here is what was returned when used with the Panorama Help file:
You will notice some variable names include a space along with another name in parenthesis. If I try to get a value for any of these types of permanent variables I get a syntax error. If I only us the first part of the name before the space I get the “variable does not exist” error. I’m befuddled.
I think it just means that those variables were declared but never given a value. Using a throwaway copy of Pan x I tried putting a text display object in a new form I gave that database. The formula was
«_PageFormat (Images)»
and I got the field or variable does not exist error. Then I ran this procedure
These permanent variables were all created by Panorama. The PageFormat variables are for holding Page Setup information. *FontHarmony holds information that Panorama 6 uses to resolve fonts (Panorama X does not use this variable once the file is converted). The others are pretty much self explanatory. There are others generated by other wizards, for example the Text Import and Export wizards have special variables that they use to hold templates.
In general you don’t want to touch any of these variables.
