Trying to make a text display list using arrayselectedbuild. I want to have the column line up, so have to adjust spacing on the fly.
I am using this formula:
arrayselectedbuild lvDailyList,¶,"",datepattern(«DF_Date»,“DAY”)+rep(" “,2)+rep(” “,switch(length(str(«Gross»)),
3,4,
4,3,
5,2,
6,1,
0))+pattern(«Gross»,”#.##")+"–"+str(length(str(«Gross»)))
Using three different data sets, I get the below results (I’m using a fixed width font). They all line up correctly except one per set. I included the length at the end to see that the length is being read wrong in the marked items:
FRI 1113.18--7
SAT 1800.45--7
SUN 1169.55--7
MON 120.45--6
TUE 435.00--3 << Should be 6
WED 317.27--6
THU 447.73--6
FRI 517.73--6
SAT 814.55--6
SUN 736.82--17<< should be 6
MON 162.27--6
TUE 143.18--6
WED 61.82--5
THU 267.73--6
FRI 1187.27--7
SAT 1793.64--7
SUN 843.64--6
MON 151.36--6
TUE 493.18--6
WED 454.55--6
THU 0.00--1 << should be 4
Any idea what is causing the length( to be misread?
str(«Gross») isn’t going to return the same value as your pattern( function. str(435.00) will return 435. That’s just 3 characters. str(736.82) is probably 736.8200000000001 or 736.8199999999999. str(0.00) is just 0.
Instead of using the switch( function, you can do it the old way.
Martin, at the risk of telling you something you already know, which I have done several times in the forum, you know you can build the array with tabs separating the data and display it in a multi-column text list and the alignment is all taken care of, right? Tom
