Panorama X 0.9.008 is now available. You can download this new version from the web site, or you can simply launch your current version of Panorama X and let it automatically update. If Panorama X is already running, choose Check for Updates in the Panorama menu.
This release contains a handful of bug fixes, and a new training movie.
Added new movie to Panorama Video Training wizard: Basic Automation.
In the Find/Select dialog, if the user double clicks on a record that isn’t currently selected, Panorama now offers to add the record to the current selection and then find it (before it would just close the dialog in that situation).
A formulafill that uses a superlookup( with a grabdata( function back into the original database now works correctly. Note that this fix only applies to formulafill – other scanning operations like select, find, etc. still do not work with this combination.
Double chevron notation is now allowed in the Morph Field dialog. Note – when using double chevron notation in a superlookup(, the formula does not show the correct values in the preview area. But it does produce the correct values when the Morph button is pressed.
Panorama now has better protection against programming errors in custom functions and libraries. If an error is detected, a notification will appear, but the initialization process will continue and Panorama will run normally.
The RegisterCustomFunction statement now has an alias – RegisterFunction. This is the name that this statement had in Panorama 6. Please note, however, that Panorama X requires the formula to be quoted, Panorama 6 did not.
Timer code (including .Initialize procedures) now work even if they end with a // comment. (A customer had submitted a database where the .Initialize procedure didn’t run because it ended with a // comment.)
All help pages now include Open Graph Protocol meta tags, which makes a nice preview show up if a link to the page is pasted into Discourse, Slack, iMessage, Twitter, Facebook, etc.
Fixed two typos in generatedataarray( error messages.
Added error checking to AddLines statement so that if an error occurs, the error message will mention AddLines instead of displaying a cryptic message based on the underlying error.
Fixed crash that could occur when clicking on an empty row in a Matrix object.
Minor documentation corrections submitted by David Thompson.
