Panorama X 0.9.002 Build 2495 Release Notes
Panorama X 0.9.002 is now available. You can download this new version from the web site, or you can simply launch your current version of Panorama X and let it automatically update. If Panorama X is already running, choose Check for Updates in the Panorama menu.
This release contains a handful of minor bug fixes. There are no new features or changes to the documentation.
  • Fixed dragging of a column when data sheet is scrolled horizontally while dragging the column.
  • The importdatabase statement now handles line breaks in the data correctly, they are no longer converted to vertical tabs. This also fixes the Import Panorama Database into Current Database wizard.
  • The Text Import wizard now warns if you try to import without setting up the configuration. A dialog sheet opens that offers to use a default configuration (all text columns), and also offers help if you want to use a custom configuration
  • Fixed error that occurred in Text Import wizard if you clicked in upper or lower list outside of any column.
  • Fixed Panorama Help wizard so that procedure code can open the help to a specific page.
  • Fixed several minor (mostly cosmetic) bugs in Site License wizard encountered when filling out the optional survey for the trial version and when making a payment on an account.
