I click on Sort Dialog, get a dialog then can’t get out of it even by clicking cancel. This also happened on other dialogs. See attached image.
I can’t duplicate this problem, it works fine. However, if you run into a situation where a dialog is stuck, press the ESCAPE key. If that doensn’t work press FUNCTION-ESCAPE, which will abort any dialog.
