Has anyone else found the “nsnotify” is not working?
I’ve programmed backup saves into hotkeys during initialisation, with an nsnotify to tell me its worked. The backup is working, but the notification isn’t.
I’ve just run a test procedure with nsnotify, and that does nothing either.
Don’t know when this stopped - probably some time in the last 6 months??
Maybe you have to allow notifications for Panorama X in System Preferences > Notifications?
In the System Preferences Notification panel, make sure that Panorama X notifications are set to Banner. It sounds like you have this set to None. Also you need to make sure that Do Not Disturb is not turned on.
Problem solved. Thanks. I didn’t know about that!!!
