here’s an example:
this gets it wrong:
field available
formulafill «» - lookup(‘assyonsls’, ‘item’, item, ‘qty’, 0, 0)
this works:
field available
formulafill datavalue(«») - lookup(‘assyonsls’, ‘item’, item, ‘qty’, 0, 0)
is this a know issue?
here’s an example:
this gets it wrong:
field available
this works:
field available
Please supply a more detailed description of the symptoms. I just tried a formulafill using «» and it worked fine.
i just tried to replicate it today and can’t, so never mind i guess.
i promise you, the problem did exist yesterday. i tried it several times because i found it unbelievable. the formulafill did produce a correct value for the first record, so i thought at first that the «» was being evaluated once then that value was used for the entire file, but that wasn’t the case. i could never figure out the trouble.
i have a sick old computer here, so i guess i shouldn’t be surprised by anything.
sorry i wasted your time.
