No Chart in the workshops
Greetings,
I’m having fun exploring the latest Pan X version (10.1 2790). I’ve been playing with the new summary workshop and crosstabs workshop. In each case I am using the “My Checkbook” database from the exchange. Each seems fine until I choose a chart (any chart) and then the data disappears, but no chart. I am using Mac OS 10.11.6. Do I need a newer OS? Or What?
Thanks
I don’t have a computer with OS X 10.11, so I can’t test it. I don’t know of any reason why it wouldn’t work on that OS version, though.
One thing you might try is to quit Panorama and relaunch it.
FWIW: I made a test with the same database “My Checkbook” from the database exchange. It works perfectly here.
I don’t think your issue is a matter of the macOS (I’m using 10.13.6), I think you were perhaps using a field that was not suitable for grouping; so you may have got to many data points to draw the chart.
I got good results with a crosstab grouped by category and on the top by month, totaling the Debit field.
I restarted Pan X - no change.
I restarted the computer (Mac Mini) - no change.
I installed Security update 2018-004 and restarted - no change.
I tried Kurt’s example - no change.
I’m seeing a similar problem. But I’m running the Mojave beta, so don’t consider it something I can complain about right now. Even with a simple set of items, trying something like a pie chart leaves me with no chart.
#6
I setup a few summary workshop charts a few weeks ago before upgrading to Mojave. Worked great. Upgraded to Mojave today, no charts. Summary tables are ok but no chart options work. Charts are completely blank.
#7
I confirm this. Charts worked in macOS 10.13.6, but they do not work in Mojave.
#8
That is disappointing.
What if you use the Display Chart in Browser command, does that work?
#9
Yes, Jim. The chart is displayed in Safari; that works well.
#10
Thanks. That’s a good work around for now.
