Minimum Requirments Pan X
What are the minimum requirements to install Panorama X?
That is:
Minimum hard disk size to install Panorama X - ? Gb
Minimum RAM ? Gb
Panorama X will run on any computer that runs macOS 10.9 or later. The program itself is currently 89 Mb (0.089 Gb), so disk usage shouldn’t be a problem. As for memory, Panorama X uses about 100 Mb empty, plus whatever the sizes of your databases are (most are tiny, for example ProVUE’s 25 year invoice database is only 25 Mb with over 40,000 invoices). Panorama X will definitely run on a system with 4Gb of memory, which I think is the minimum for any computer shipped in the last 5-6 years (probably more).
